Panel option editor - Error
I’m implementing a custom panel option editor and keep encountering a yarn dev error that I suspect comes from incorrect syntax when I set the editor property.
195:15 error Component definition is missing display name react/display-name
I’ve been following the tutorial in docs, but I think the issue is with my React code…
If the issue is in fact with my React syntax, should I be using something other than an arrow function at line 195?
(Note: MonacoEditor is just a text editor I use. )
Grafana Version: v8.0.6
OS: Ubuntu 20.04.2 LTS
Update
The issue was with my React syntax. I was able to fix the issue by replacing
editor: (props) => {
with
editor:function myNamedFunction(props){
