Panel Drill Down Link With Variable URL Param Does Not Refresh Dashboard
I added a Drilldown / detail link to a Panel, the Type is ‘dashboard’ and the Dashboard is the same one where the panel is. I provide a URL Param as well which updates a variable. When I click on the Panel, the variable is added to the browser URL params, but the Dashboard is not reloaded/refreshed and does not show the new metrics that matches the URL param. As a result I have to hit the ‘Reload’ button so that the dashboard page will reload.
Is there a way for the dashboard to update upon the change of a variable thru URL param, without the user having to hit the browser Reload button?
Hello there,
I encounter the same issue.
Do you fix the issue now?
Could you please share your solution?
Thanks a lot.
The issue has been fixed by https://github.com/grafana/grafana/commit/fa2781391a7f1e684d545957d9186847a2c12ce1
