Hi Grafana Community,
We’re experiencing an issue with the stat panel panel links . When switching between environments (e.g., staging, production, etc.) using a variable or URL parameter, the panel link does not update or render the correct value unless the page is manually reloaded.
Steps to Reproduce:
- Configure a panel with a dynamic link using variables (e.g.,
${env}). - Switch environments via a dropdown or URL parameter (e.g., from
stagtoprod). - Observe that the panel link does not reflect the new environment.
- Manually reload the page — the link then updates correctly.
Expected Behavior:
The panel link should dynamically update based on the selected environment without requiring a manual page reload.
Actual Behavior:
The link remains stale or incorrect until the user manually refreshes the page.
Environment:
- Grafana version: v11.4.0
- Browser: Chrome 136.0.7103.114
- Data source: OpenSearch
- Panel type: Stat panel
Let me know if any additional details would help. Thanks in advance for your support!
