I am trying to submit a plugin via Grafana Cloud.
The plugin id is opengemini-opengemini-datasource,and my cloud username is opengemini.
But it return an error “Org not found opengemini”.
I don’t know what went wrong
Please open a support ticket and someone will help you with the situation. Keep in mind that your organization name (display name) is not the same as your organization slug (internal id, what you should use for your plugin)
Log in into grafana.com and go to Settings in the sidebar. Observe the url in the browser. It should look like this: https://grafana.com/orgs/your-org-slug/settings.
If that your-org-slug doesn’t match what you want you can ask the support person to change it for you.
Thank you for your response
I think I should ask the support person to change the org-slug
