10.0.0 - What are you trying to achieve?
Expected the Grafana session to be logged out and prompt for login screen again.on restart of service or reboot of system. - How are you trying to achieve it?
1.Login to Grafana UI
2.Restart Grafana service from windows services
- Go to earlier logged in Grafana UI
What happened?
I restarted Grafana service in windows ,but the Grafana session was not killed/logged out…
Even with inbuild Grafana login mechanism we have same issue -
Expected the Grafana session to be logged out and prompt for login screen again. -
No
- Did you follow any online instructions? If so, what is the URL?
Did not find any
