Grafana Enterprise 11.6, running on Azure Kubernetes Service (AKS). -
I want to ensure that Grafana respects OIDC session validity by stopping token rotation and expiring sessions when the upstream Keycloak session is terminated. -
Using Generic OIDC authentication with Keycloak. I’ve enabled refresh token rotation with the following config:
token_rotation_interval_minutes = 4- Keycloak client has:
- Refresh token reuse disabled
- Revoke refresh tokens enabled
- Short token lifespans 5 min
- Verified session termination in keycloak
What happened?
Grafana successfully logs in via Keycloak. If I kill the Keycloak session (via admin UI or REST API), the Grafana session continues unaffected. Even the rotate calls succeed, they don’t seem to call Keycloak at all. There are no relevant logs or requests to Keycloak during the token rotation period. I see that the grafana_session’s browser expiry time gets incremented with each rotate. -
I expected Grafana to fail to rotate tokens (and invalidate the session) once the Keycloak session was removed. I also expected token rotation to involve calling Keycloak’s/tokenendpoint, which doesn’t appear to happen even after auth token expiry. -
[auth.generic_oauth]
enabled = true
name = OAuth
allow_sign_up = true
client_id = grafana
client_secret = ...
scopes = openid profile email
auth_url = https://....example.com/realms/myrealm/protocol/openid-connect/auth
token_url = https://....example.com/realms/myrealm/protocol/openid-connect/token
api_url = https://....example.com/realms/myrealm/protocol/openid-connect/userinfo
role_attribute_path = contains(groups[*], 'grafana-admin') && 'Admin' || 'Viewer'
use_refresh_token = true
No errors. Even after the Keycloak session is terminated, Grafana continues to function normally. In debug mode, I see no logs related to token refresh hitting Keycloak when expected. -
Yes, followed:
https://grafana.com/docs/grafana/latest/setup-grafana/configure-security/configure-authentication/generic-oauth/
Also cross-checked with Keycloak docs on session and token revocation behavior.
Thank You
