10.0.0 -
Expected the Grafana session to be logged out and prompt for login screen again, on restart of service -
I restarted Grafana service in windows ,but the Grafana session was not killed/logged out.
Expected the Grafana session to be logged out and prompt for login screen again. -
What happened?
I restarted Grafana service in windows ,but the Grafana session was not killed/logged out. -
No -
