What Grafana version and what operating system are you using? 9.3.8
What are you trying to achieve? Want to use date pickers in filter variables.
How are you trying to achieve it? Trying to add a filter and use date pickers.
What happened? Unable to find any variable type relative to date pickers
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. NA
HI @praharsha
What is your datasource? Have you read through the docs on this subject?
Elastic Search datasource is being used
Hi @praharsha
Have you read this? The table indicates that your current dashboard time range would be used by your Lucene query filter.
