*Solved* Dashboard time range is not applied to variable query
from: Elasticsearch query editor | Grafana documentation
{"find": "terms", "field": "hostname.keyword", "size": 1000}
Returns a list of values for a keyword using term aggregation. Query will use current dashboard time range as time range query.
However when I do my query:
{“find”:“terms”, “field”:“tag.my_variable.keyword”, “size”: 25}
I see the same set of alphabetized variables from any dashboard time ranges. The list of “my_variable” is changing constantly and at many points should be blank.
Messing with the variable query options. I cannot find any reliable documentation on the full list of query options I can do. All I can see are the few options on here: Elasticsearch query editor | Grafana documentation
from which there’s little to extrapolate on the various things I believe I can pass in to a grafana query.
  • What happened?
The list of my_variable should change.
pasted above.
no errors.
url shared above.
My data was the issue here. This is working as expected.
