I’m using elasticsearch as my datasource. When I change date and time in the grafana, the variable values are not updating. I need to add timestamps in my variable query. So, how can I achieve it?
You’ll have to enable per template variable a setting for refreshing on time range change.
Marcus
Thank you sir, it solved my problem!
