Nodegraph throws exception when nodes and edges datasets are empty
how to handle Grafana node graph throwing exception when nodes and edge datasets are empty?
    version 12.2
    Nodegraph visualization
    Querying prometheus metrics using two seperate queries to get two datasets nodes and edges
  • What happened?
    There are instances when my datasets have no data. In such a case the node graph throws exception saying it’s looking for an “id” column.
    I did use a workaround by creating dummy node and edges, so the panel shows “No Connections” instead of throwing exceptions. I just want to know if there’s a better way to handle this.
    Nodes:
    label_replace(
    label_replace(
    vector(0),
    “id”,“no-data”,“”,“”
    “title”,“No Agents Connected”,“”,“”
    unless
    <my actual query>
    Edges:
    label_replace(
    label_replace(
    label_replace(
    vector(0),
    “id”,“no-edge”,“”,“”
    “source”,“no-data”,“”,“”
    “target”,“no-data”,“”,“”
    unless
    <My actual query>
    Show “No Data” when datasets are empty
    Node graph | Grafana documentation
Try this..
Nodes:
label_replace(vector(0), “id”, “no-data”, “”, “”)
|> label_replace(“title”, “No Agents Connected”, “”, “”)
unless
(<your_query>)
Edges:
label_replace(vector(0), “id”, “no-edge”, “”, “”)
|> label_replace(“source”, “no-data”, “”, “”)
|> label_replace(“target”, “no-data”, “”, “”)
unless
(<your_query>)
Thank you, that worked
