Grafana version: 11
Operating system: Kubernetes
I am trying to create a network weathermap using the Grafana Node Graph plugin. -
I successfully structured the required data frame and fetched it from Prometheus. -
What happened?
When I create only the nodes table, I can see the nodes in the panel.
When I create only the edges table, I can see the edges in the panel.
However, when I combine both tables, the panel displays a notification:
“12 nodes are hidden for performance reasons.” -
The panel gets stuck on “Computing layout” and freezes.
I expected the Node Graph plugin to work smoothly with Prometheus and render the full network map without issues. -
Here is the PromQL query I used:
max by(name, id, color, source, target) (
label_replace(
label_replace(
label_replace(
ifTable_ifOutOctets{ifAlias=~".*core.*"},
"id", "$1", "ifAlias", "(.*)"
"source", "$1", "name", "(.*)"
"target", "$1", "ifAlias", "core:([^:]+)"
I used Reduce Mode with Series to Rows.
Yes, I received the following message in the Grafana panel: -
The panel gets stuck on “Computing layout” and becomes unresponsive. “Computing layout”
Yes , node graph documentations
