NodeGraph Panel
I have Installed Grafana v7.5.2. In this Grafana version, they have given a “NodeGraph Panel (beta)” Visualization. I need to built a topology View Dashboard.
How I can built a dashboard ? ( I tried to installed X-RAY plugins also.)??
Hi @rjain2303 check out the X-ray data source documentation’s “Service map” subsection which should walk you through how to get to the Node Graph panel view. X-Ray plugin for Grafana | Grafana Labs
Thanks for reply!!!
But i don’t have AWS AUTH detail so How I can add the X-RAY datasource without AWS detail.
I need to built a Network Topology View. for this, I want to use Visualization “NodeGraph Panel (beta)”. Please suggest how i can achieve this requirement.
Use Diagram plugin for Grafana | Grafana Labs
