Free v12.1.1 -
I’m trying to create a node graph to show data lineage. -
I’m achieving it using MySQL. -
What happened?
I am able to graph the nodes and edges, however the edges have no directional arrow. This occurs with both complex and simple datasets. -
I expect edges to have arrows to show direction. -
No errors. -
I have been using the node graph documentation. Node graph | Grafana documentation
Simple example:
Expected:
Any help is appreciated, thank you.
