Can you connect to the SQL server from the Grafana machine using a command-
link SQL client using the same username / password as you’re putting into
Grafana?
This error is occurring because there is no server listening at the hostname and port you assigned. It literally means that the machine exists but that it has no services listening on the specified port . So, no connection can be established. Generally, it happens that something is preventing a connection to the port or hostname. Either there is a firewall blocking the connection or the process that is hosting the service is not listening on that specific port. This may be because it is not running at all or because it is listening on a different port.
