Newly installed plugins are not visible & log file is not updating with the passage of time & Date
Hi, I have installed Grafana “grafana-6.5.2.windows-amd64.zip” . I have faced a lot of issue in last days .
  1. Newly installed Plugins are not visible whenever i tried to create new dashboard or visualization.
  2. If i create variable for one dashboard it reflects on all dashboards and filters/variables for that page disappear.
    However, newly installed plugins are showing in plugin folder and in log file. Any solution for this issue?
Platform : Windows
Please include your configuration files. Enable debug logging, stop and start Grafana server process and include Grafana server log here.
I have seen log file. Its not updating on the basis of date & time. Like today is 20 January but log file contains events of 16 January.
Logs :
t=2019-12-31T11:29:32+0500 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=GET path=/api/gnet/dashboards/undefined status=404 remote_addr=[::1] time_ms=256 size=60 referer=http://localhost:8080/dashboard/import
t=2019-12-31T11:33:23+0500 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=POST path=/api/dashboards/db/ status=412 remote_addr=[::1] time_ms=16 size=88 referer=“http://localhost:8080/d/2G_bm0LWk/aix-nmon-individual-disks?editview=dashboard_json&orgId=1”
t=2019-12-31T11:49:46+0500 lvl=eror msg=“Dashboard not found” logger=context userId=1 orgId=1 uname=admin error=“Dashboard not found”
t=2019-12-31T11:49:46+0500 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=GET path=/api/dashboards/uid/Gn9D1ZWmk status=404 remote_addr=[::1] time_ms=1 size=33 referer=http://localhost:8080/dashboard/import
t=2019-12-31T11:53:17+0500 lvl=eror msg=“Dashboard not found” logger=context userId=1 orgId=1 uname=admin error=“Dashboard not found”
t=2019-12-31T11:53:17+0500 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=GET path=/api/dashboards/uid/H0xWYyyik status=404 remote_addr=[::1] time_ms=0 size=33 referer=“http://localhost:8080/d/H0xWYyyik/1-node-exporter-0-18-x?editview=settings&orgId=1”
t=2019-12-31T11:55:06+0500 lvl=eror msg=“Dashboard not found” logger=context userId=1 orgId=1 uname=admin error=“Dashboard not found”
t=2019-12-31T11:55:06+0500 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=GET path=/api/dashboards/uid/2G_bm0LWk status=404 remote_addr=[::1] time_ms=0 size=33 referer=“http://localhost:8080/d/2G_bm0LWk/aix-nmon-individual-disks?editview=settings”
t=2019-12-31T11:59:30+0500 lvl=eror msg=“Dashboard not found” logger=context userId=1 orgId=1 uname=admin error=“Dashboard not found”
t=2019-12-31T11:59:30+0500 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=GET path=/api/dashboards/uid/2G_bm0LWk status=404 remote_addr=[::1] time_ms=0 size=33 referer=“http://localhost:8080/d/2G_bm0LWk/aix-nmon-individual-disks?orgId=1”
t=2019-12-31T12:04:18+0500 lvl=info msg=“Shutdown started” logger=server reason=“System signal: interrupt”
t=2019-12-31T12:04:18+0500 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2019-12-31T12:04:18+0500 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2019-12-31T12:04:18+0500 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2019-12-31T12:04:18+0500 lvl=info msg=“Stopped RemoteCache” logger=server reason=“context canceled”
t=2019-12-31T12:04:18+0500 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2019-12-31T12:04:18+0500 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2019-12-31T12:04:18+0500 lvl=info msg=“Stopped Stream Manager”
t=2019-12-31T12:04:18+0500 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
t=2019-12-31T12:04:18+0500 lvl=info msg=“Stopped AlertEngine” logger=server reason=“context canceled”
t=2019-12-31T12:04:18+0500 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2019-12-31T12:04:18+0500 lvl=eror msg=“Server shutdown” logger=server reason=nil
t=2019-12-31T12:07:03+0500 lvl=info msg=“Starting Grafana” logger=server version=6.5.2 commit=742d165 branch=HEAD compiled=2019-12-11T17:41:26+0500
t=2019-12-31T12:07:03+0500 lvl=info msg=“Config loaded from” logger=settings file=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2/conf/defaults.ini
t=2019-12-31T12:07:03+0500 lvl=info msg=“Config loaded from” logger=settings file=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\custom.ini
t=2019-12-31T12:07:03+0500 lvl=info msg=“Path Home” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2
t=2019-12-31T12:07:03+0500 lvl=info msg=“Path Data” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data
t=2019-12-31T12:07:03+0500 lvl=info msg=“Path Logs” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\log
t=2019-12-31T12:07:03+0500 lvl=info msg=“Path Plugins” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\plugins
t=2019-12-31T12:07:03+0500 lvl=info msg=“Path Provisioning” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\provisioning
t=2019-12-31T12:07:03+0500 lvl=info msg=“App mode production” logger=settings
t=2019-12-31T12:07:03+0500 lvl=info msg=“Initializing SqlStore” logger=server
t=2019-12-31T12:07:03+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2019-12-31T12:07:03+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2019-12-31T12:07:03+0500 lvl=info msg=“Initializing HTTPServer” logger=server
t=2019-12-31T12:07:03+0500 lvl=info msg=“Initializing OSSLicensingService” logger=server
t=2019-12-31T12:07:03+0500 lvl=info msg=“Initializing SearchService” logger=server
t=2019-12-31T12:07:03+0500 lvl=info msg=“Initializing RemoteCache” logger=server
t=2019-12-31T12:07:03+0500 lvl=info msg=“Initializing QuotaService” logger=server
t=2019-12-31T12:07:03+0500 lvl=info msg=“Initializing ServerLockService” logger=server
t=2019-12-31T12:07:03+0500 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2019-12-31T12:07:03+0500 lvl=info msg=“Initializing PluginManager” logger=server
t=2019-12-31T12:07:03+0500 lvl=info msg=“Starting plugin search” logger=plugins
t=2019-12-31T12:07:04+0500 lvl=info msg=“Initializing RenderingService” logger=server
t=2019-12-31T12:07:04+0500 lvl=info msg=“Initializing AlertEngine” logger=server
t=2019-12-31T12:07:04+0500 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2019-12-31T12:07:04+0500 lvl=info msg=“Initializing HooksService” logger=server
t=2019-12-31T12:07:04+0500 lvl=info msg=“Initializing LoginService” logger=server
t=2019-12-31T12:07:04+0500 lvl=info msg=“Initializing InternalMetricsService” logger=server
t=2019-12-31T12:07:04+0500 lvl=info msg=“Initializing TracingService” logger=server
t=2019-12-31T12:07:04+0500 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2019-12-31T12:07:04+0500 lvl=info msg=“Initializing CleanUpService” logger=server
t=2019-12-31T12:07:04+0500 lvl=info msg=“Initializing NotificationService” logger=server
t=2019-12-31T12:07:04+0500 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2019-12-31T12:07:04+0500 lvl=info msg=“Backend rendering via phantomJS” logger=rendering
t=2019-12-31T12:07:04+0500 lvl=warn msg=“phantomJS is deprecated and will be removed in a future release. You should consider migrating from phantomJS to grafana-image-renderer plugin.” logger=rendering
t=2019-12-31T12:07:04+0500 lvl=info msg=“Initializing Stream Manager”
t=2019-12-31T12:07:04+0500 lvl=info msg=“HTTP Server Listen” logger=http.server address=[::]:8080 protocol=http subUrl= socket=
t=2020-01-10T19:31:48+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-01-10T19:31:48+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2020-01-10T19:32:47+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-01-10T19:32:47+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2020-01-10T19:33:29+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-01-10T19:33:29+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2020-01-10T19:33:52+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-01-10T19:33:52+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2020-01-10T19:36:19+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-01-10T19:36:19+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2020-01-15T17:36:56+0500 lvl=info msg=“Starting Grafana” logger=server version=6.5.2 commit=742d165 branch=HEAD compiled=2019-12-11T17:41:26+0500
t=2020-01-15T17:36:56+0500 lvl=info msg=“Config loaded from” logger=settings file=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2/conf/defaults.ini”
t=2020-01-15T17:36:56+0500 lvl=info msg=“Config loaded from” logger=settings file=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\custom.ini”
t=2020-01-15T17:36:56+0500 lvl=info msg=“Path Home” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2”
t=2020-01-15T17:36:56+0500 lvl=info msg=“Path Data” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data”
t=2020-01-15T17:36:56+0500 lvl=info msg=“Path Logs” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\log”
t=2020-01-15T17:36:56+0500 lvl=info msg=“Path Plugins” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\plugins”
t=2020-01-15T17:36:56+0500 lvl=info msg=“Path Provisioning” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\provisioning”
t=2020-01-15T17:36:56+0500 lvl=info msg=“App mode production” logger=settings
t=2020-01-15T17:36:56+0500 lvl=info msg=“Initializing SqlStore” logger=server
t=2020-01-15T17:36:56+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-01-15T17:36:56+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2020-01-15T17:36:56+0500 lvl=info msg=“Initializing HTTPServer” logger=server
t=2020-01-15T17:36:56+0500 lvl=info msg=“Initializing OSSLicensingService” logger=server
t=2020-01-15T17:36:56+0500 lvl=info msg=“Initializing SearchService” logger=server
t=2020-01-15T17:36:56+0500 lvl=info msg=“Initializing RemoteCache” logger=server
t=2020-01-15T17:36:56+0500 lvl=info msg=“Initializing QuotaService” logger=server
t=2020-01-15T17:36:56+0500 lvl=info msg=“Initializing ServerLockService” logger=server
t=2020-01-15T17:36:56+0500 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2020-01-15T17:36:56+0500 lvl=info msg=“Initializing PluginManager” logger=server
t=2020-01-15T17:36:56+0500 lvl=info msg=“Starting plugin search” logger=plugins
t=2020-01-15T17:36:57+0500 lvl=info msg=“Registering plugin” logger=plugins name=Clock
t=2020-01-15T17:36:57+0500 lvl=info msg=“Registering plugin” logger=plugins name=“Pie Chart”
t=2020-01-15T17:36:57+0500 lvl=info msg=“Registering plugin” logger=plugins name=Multistat
t=2020-01-15T17:36:57+0500 lvl=info msg=“Initializing RenderingService” logger=server
t=2020-01-15T17:36:57+0500 lvl=info msg=“Initializing AlertEngine” logger=server
t=2020-01-15T17:36:57+0500 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2020-01-15T17:36:57+0500 lvl=info msg=“Initializing HooksService” logger=server
t=2020-01-15T17:36:57+0500 lvl=info msg=“Initializing LoginService” logger=server
t=2020-01-15T17:36:57+0500 lvl=info msg=“Initializing InternalMetricsService” logger=server
t=2020-01-15T17:36:57+0500 lvl=info msg=“Initializing TracingService” logger=server
t=2020-01-15T17:36:57+0500 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2020-01-15T17:36:57+0500 lvl=info msg=“Initializing CleanUpService” logger=server
t=2020-01-15T17:36:57+0500 lvl=info msg=“Initializing NotificationService” logger=server
t=2020-01-15T17:36:57+0500 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2020-01-15T17:36:57+0500 lvl=info msg=“Backend rendering via phantomJS” logger=rendering
t=2020-01-15T17:36:57+0500 lvl=warn msg=“phantomJS is deprecated and will be removed in a future release. You should consider migrating from phantomJS to grafana-image-renderer plugin.” logger=rendering
t=2020-01-15T17:36:57+0500 lvl=info msg=“Initializing Stream Manager”
t=2020-01-15T17:36:57+0500 lvl=info msg=“HTTP Server Listen” logger=http.server address=[::]:3000 protocol=http subUrl= socket=
t=2020-01-16T19:56:25+0500 lvl=info msg=“Starting Grafana” logger=server version=6.5.2 commit=742d165 branch=HEAD compiled=2019-12-11T17:41:26+0500
t=2020-01-16T19:56:25+0500 lvl=info msg=“Config loaded from” logger=settings file=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2/conf/defaults.ini”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Config loaded from” logger=settings file=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\custom.ini”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Path Home” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Path Data” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Path Logs” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\log”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Path Plugins” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\plugins”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Path Provisioning” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\provisioning”
t=2020-01-16T19:56:25+0500 lvl=info msg=“App mode production” logger=settings
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing SqlStore” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-01-16T19:56:25+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing HTTPServer” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing OSSLicensingService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing SearchService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing RemoteCache” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing QuotaService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing ServerLockService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing PluginManager” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Starting plugin search” logger=plugins
t=2020-01-16T19:56:25+0500 lvl=info msg=“Registering plugin” logger=plugins name=Clock
t=2020-01-16T19:56:25+0500 lvl=info msg=“Registering plugin” logger=plugins name=“Pie Chart”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Registering plugin” logger=plugins name=Multistat
t=2020-01-16T19:56:25+0500 lvl=info msg=“Registering plugin” logger=plugins name=Discrete
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing RenderingService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing AlertEngine” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing HooksService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing LoginService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing InternalMetricsService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing TracingService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing CleanUpService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing NotificationService” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2020-01-16T19:56:25+0500 lvl=info msg=“Backend rendering via phantomJS” logger=rendering
t=2020-01-16T19:56:25+0500 lvl=warn msg=“phantomJS is deprecated and will be removed in a future release. You should consider migrating from phantomJS to grafana-image-renderer plugin.” logger=rendering
t=2020-01-16T19:56:25+0500 lvl=info msg=“Initializing Stream Manager”
t=2020-01-16T19:56:25+0500 lvl=eror msg=“Stopped HTTPServer” logger=server reason=“failed to open listener on address 0.0.0.0:3000: listen tcp 0.0.0.0:3000: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted.”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Stopped Stream Manager”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Stopped RemoteCache” logger=server reason=“context canceled”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
t=2020-01-16T19:56:25+0500 lvl=info msg=“Stopped AlertEngine” logger=server reason=“context canceled”
t=2020-01-16T19:56:26+0500 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2020-01-16T19:56:26+0500 lvl=eror msg=“A service failed” logger=server err=“failed to open listener on address 0.0.0.0:3000: listen tcp 0.0.0.0:3000: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted.”
t=2020-01-16T19:56:26+0500 lvl=eror msg=“Server shutdown” logger=server reason=“failed to open listener on address 0.0.0.0:3000: listen tcp 0.0.0.0:3000: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted.”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Starting Grafana” logger=server version=6.5.2 commit=742d165 branch=HEAD compiled=2019-12-11T17:41:26+0500
t=2020-01-16T19:56:52+0500 lvl=info msg=“Config loaded from” logger=settings file=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2/conf/defaults.ini”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Config loaded from” logger=settings file=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\custom.ini”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Path Home” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Path Data” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Path Logs” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\log”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Path Plugins” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\plugins”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Path Provisioning” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\provisioning”
t=2020-01-16T19:56:52+0500 lvl=info msg=“App mode production” logger=settings
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing SqlStore” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-01-16T19:56:52+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing HTTPServer” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing OSSLicensingService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing SearchService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing RemoteCache” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing QuotaService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing ServerLockService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing PluginManager” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Starting plugin search” logger=plugins
t=2020-01-16T19:56:52+0500 lvl=info msg=“Registering plugin” logger=plugins name=Clock
t=2020-01-16T19:56:52+0500 lvl=info msg=“Registering plugin” logger=plugins name=“Pie Chart”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Registering plugin” logger=plugins name=Multistat
t=2020-01-16T19:56:52+0500 lvl=info msg=“Registering plugin” logger=plugins name=Discrete
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing RenderingService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing AlertEngine” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing HooksService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing LoginService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing InternalMetricsService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing TracingService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing CleanUpService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing NotificationService” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2020-01-16T19:56:52+0500 lvl=info msg=“Backend rendering via phantomJS” logger=rendering
t=2020-01-16T19:56:52+0500 lvl=warn msg=“phantomJS is deprecated and will be removed in a future release. You should consider migrating from phantomJS to grafana-image-renderer plugin.” logger=rendering
t=2020-01-16T19:56:52+0500 lvl=info msg=“Initializing Stream Manager”
t=2020-01-16T19:56:52+0500 lvl=eror msg=“Stopped HTTPServer” logger=server reason=“failed to open listener on address 0.0.0.0:3000: listen tcp 0.0.0.0:3000: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted.”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Stopped RemoteCache” logger=server reason=“context canceled”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Stopped AlertEngine” logger=server reason=“context canceled”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Stopped Stream Manager”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2020-01-16T19:56:52+0500 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2020-01-16T19:56:53+0500 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2020-01-16T19:56:53+0500 lvl=eror msg=“A service failed” logger=server err=“failed to open listener on address 0.0.0.0:3000: listen tcp 0.0.0.0:3000: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted.”
t=2020-01-16T19:56:53+0500 lvl=eror msg=“Server shutdown” logger=server reason=“failed to open listener on address 0.0.0.0:3000: listen tcp 0.0.0.0:3000: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted.”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Starting Grafana” logger=server version=6.5.2 commit=742d165 branch=HEAD compiled=2019-12-11T17:41:26+0500
t=2020-01-16T19:57:52+0500 lvl=info msg=“Config loaded from” logger=settings file=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2/conf/defaults.ini”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Config loaded from” logger=settings file=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\custom.ini”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Path Home” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Path Data” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Path Logs” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\log”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Path Plugins” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\plugins”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Path Provisioning” logger=settings path=“C:\Program Files\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\provisioning”
t=2020-01-16T19:57:52+0500 lvl=info msg=“App mode production” logger=settings
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing SqlStore” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-01-16T19:57:52+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing HTTPServer” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing OSSLicensingService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing SearchService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing RemoteCache” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing QuotaService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing ServerLockService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing PluginManager” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Starting plugin search” logger=plugins
t=2020-01-16T19:57:52+0500 lvl=info msg=“Registering plugin” logger=plugins name=Clock
t=2020-01-16T19:57:52+0500 lvl=info msg=“Registering plugin” logger=plugins name=“Pie Chart”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Registering plugin” logger=plugins name=Multistat
t=2020-01-16T19:57:52+0500 lvl=info msg=“Registering plugin” logger=plugins name=Discrete
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing RenderingService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing AlertEngine” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing HooksService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing LoginService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing InternalMetricsService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing TracingService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing CleanUpService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing NotificationService” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2020-01-16T19:57:52+0500 lvl=info msg=“Backend rendering via phantomJS” logger=rendering
t=2020-01-16T19:57:52+0500 lvl=warn msg=“phantomJS is deprecated and will be removed in a future release. You should consider migrating from phantomJS to grafana-image-renderer plugin.” logger=rendering
t=2020-01-16T19:57:52+0500 lvl=info msg=“Initializing Stream Manager”
t=2020-01-16T19:57:52+0500 lvl=eror msg=“Stopped HTTPServer” logger=server reason=“failed to open listener on address 0.0.0.0:3000: listen tcp 0.0.0.0:3000: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted.”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Stopped Stream Manager”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Stopped RemoteCache” logger=server reason=“context canceled”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2020-01-16T19:57:52+0500 lvl=info msg=“Stopped AlertEngine” logger=server reason=“context canceled”
t=2020-01-16T19:57:53+0500 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2020-01-16T19:57:53+0500 lvl=eror msg=“A service failed” logger=server err=“failed to open listener on address 0.0.0.0:3000: listen tcp 0.0.0.0:3000: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted.”
t=2020-01-16T19:57:53+0500 lvl=eror msg=“Server shutdown” logger=server reason=“failed to open listener on address 0.0.0.0:3000: listen tcp 0.0.0.0:3000: bind: Only one usage of each socket address (protocol/network address/port) is normally permitted.”
Config file for logs
[log]
Either “console”, “file”, “syslog”. Default is console and file
Use space to separate multiple modes, e.g. “console file”
mode = console file
Either “debug”, “info”, “warn”, “error”, “critical”, default is “info”
#level = info
level = debug
Only one instance is showing in task manager.
but when i execute netstat -ano command on Command prompt. Its shows this one . Please see attached screenshot
Is it ok or having some issues . Anyhow in task manager only one instance is showing.
If you kill the running instance and try to start it again, does that work?
Isn’t it risky ? I don’t have any backup of all the dashboards.
Updated Logs @anon34853223
t=2020-01-20T17:05:56+0500 lvl=info msg=“Shutdown started” logger=server reason=“System signal: interrupt”
t=2020-01-20T17:05:56+0500 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2020-01-20T17:05:56+0500 lvl=info msg=“Stopped Stream Manager”
t=2020-01-20T17:05:56+0500 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2020-01-20T17:05:56+0500 lvl=info msg=“Stopped RemoteCache” logger=server reason=“context canceled”
t=2020-01-20T17:05:56+0500 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2020-01-20T17:05:56+0500 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2020-01-20T17:05:56+0500 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2020-01-20T17:05:56+0500 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2020-01-20T17:05:56+0500 lvl=info msg=“Stopped AlertEngine” logger=server reason=“context canceled”
t=2020-01-20T17:05:56+0500 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
t=2020-01-20T17:05:56+0500 lvl=eror msg=“Server shutdown” logger=server reason=nil
t=2020-01-20T17:05:59+0500 lvl=info msg=“Starting Grafana” logger=server version=6.5.2 commit=742d165 branch=HEAD compiled=2019-12-11T17:41:26+0500
t=2020-01-20T17:05:59+0500 lvl=info msg=“Config loaded from” logger=settings file=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2/conf/defaults.ini
t=2020-01-20T17:05:59+0500 lvl=info msg=“Config loaded from” logger=settings file=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\custom.ini
t=2020-01-20T17:05:59+0500 lvl=info msg=“Path Home” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2
t=2020-01-20T17:05:59+0500 lvl=info msg=“Path Data” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data
t=2020-01-20T17:05:59+0500 lvl=info msg=“Path Logs” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\log
t=2020-01-20T17:05:59+0500 lvl=info msg=“Path Plugins” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\plugins
t=2020-01-20T17:05:59+0500 lvl=info msg=“Path Provisioning” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\provisioning
t=2020-01-20T17:05:59+0500 lvl=info msg=“App mode production” logger=settings
t=2020-01-20T17:05:59+0500 lvl=info msg=“Initializing SqlStore” logger=server
t=2020-01-20T17:05:59+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-01-20T17:05:59+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2020-01-20T17:05:59+0500 lvl=info msg=“Initializing HTTPServer” logger=server
t=2020-01-20T17:05:59+0500 lvl=info msg=“Initializing OSSLicensingService” logger=server
t=2020-01-20T17:05:59+0500 lvl=info msg=“Initializing SearchService” logger=server
t=2020-01-20T17:05:59+0500 lvl=info msg=“Initializing RemoteCache” logger=server
t=2020-01-20T17:05:59+0500 lvl=info msg=“Initializing QuotaService” logger=server
t=2020-01-20T17:05:59+0500 lvl=info msg=“Initializing ServerLockService” logger=server
t=2020-01-20T17:05:59+0500 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2020-01-20T17:05:59+0500 lvl=info msg=“Initializing PluginManager” logger=server
t=2020-01-20T17:05:59+0500 lvl=info msg=“Starting plugin search” logger=plugins
t=2020-01-20T17:06:00+0500 lvl=info msg=“Initializing RenderingService” logger=server
t=2020-01-20T17:06:00+0500 lvl=info msg=“Initializing AlertEngine” logger=server
t=2020-01-20T17:06:00+0500 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2020-01-20T17:06:00+0500 lvl=info msg=“Initializing HooksService” logger=server
t=2020-01-20T17:06:00+0500 lvl=info msg=“Initializing LoginService” logger=server
t=2020-01-20T17:06:00+0500 lvl=info msg=“Initializing InternalMetricsService” logger=server
t=2020-01-20T17:06:00+0500 lvl=info msg=“Initializing TracingService” logger=server
t=2020-01-20T17:06:00+0500 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2020-01-20T17:06:00+0500 lvl=info msg=“Initializing CleanUpService” logger=server
t=2020-01-20T17:06:00+0500 lvl=info msg=“Initializing NotificationService” logger=server
t=2020-01-20T17:06:00+0500 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2020-01-20T17:06:00+0500 lvl=info msg=“Backend rendering via phantomJS” logger=rendering
t=2020-01-20T17:06:00+0500 lvl=warn msg=“phantomJS is deprecated and will be removed in a future release. You should consider migrating from phantomJS to grafana-image-renderer plugin.” logger=rendering
t=2020-01-20T17:06:00+0500 lvl=info msg=“Initializing Stream Manager”
t=2020-01-20T17:06:00+0500 lvl=info msg=“HTTP Server Listen” logger=http.server address=[::]:8080 protocol=http subUrl= socket=
t=2020-01-20T17:08:08+0500 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=POST path=/api/tsdb/query status=400 remote_addr=[::1] time_ms=65 size=241 referer=“http://localhost:8080/d/Sj4YWxPWk/event-plot?orgId=1”
t=2020-01-20T17:08:08+0500 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=POST path=/api/tsdb/query status=400 remote_addr=[::1] time_ms=2 size=272 referer=“http://localhost:8080/d/Sj4YWxPWk/event-plot?orgId=1”
t=2020-01-20T17:21:28+0500 lvl=info msg=“Shutdown started” logger=server reason=“System signal: interrupt”
t=2020-01-20T17:21:28+0500 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2020-01-20T17:21:28+0500 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
t=2020-01-20T17:21:28+0500 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2020-01-20T17:21:28+0500 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2020-01-20T17:21:28+0500 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2020-01-20T17:21:28+0500 lvl=info msg=“Stopped RemoteCache” logger=server reason=“context canceled”
t=2020-01-20T17:21:28+0500 lvl=info msg=“Stopped Stream Manager”
t=2020-01-20T17:21:28+0500 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2020-01-20T17:21:28+0500 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2020-01-20T17:21:28+0500 lvl=info msg=“Stopped AlertEngine” logger=server reason=“context canceled”
t=2020-01-20T17:21:28+0500 lvl=eror msg=“Server shutdown” logger=server reason=nil
t=2020-01-20T17:21:30+0500 lvl=info msg=“Starting Grafana” logger=server version=6.5.2 commit=742d165 branch=HEAD compiled=2019-12-11T17:41:26+0500
t=2020-01-20T17:21:30+0500 lvl=info msg=“Config loaded from” logger=settings file=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2/conf/defaults.ini
t=2020-01-20T17:21:30+0500 lvl=info msg=“Config loaded from” logger=settings file=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\custom.ini
t=2020-01-20T17:21:30+0500 lvl=info msg=“Path Home” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2
t=2020-01-20T17:21:30+0500 lvl=info msg=“Path Data” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data
t=2020-01-20T17:21:30+0500 lvl=info msg=“Path Logs” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\log
t=2020-01-20T17:21:30+0500 lvl=info msg=“Path Plugins” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\plugins
t=2020-01-20T17:21:30+0500 lvl=info msg=“Path Provisioning” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\provisioning
t=2020-01-20T17:21:30+0500 lvl=info msg=“App mode production” logger=settings
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing SqlStore” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-01-20T17:21:30+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing HTTPServer” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing OSSLicensingService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing SearchService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing RemoteCache” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing QuotaService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing ServerLockService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing PluginManager” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Starting plugin search” logger=plugins
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing RenderingService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing AlertEngine” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing HooksService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing LoginService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing InternalMetricsService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing TracingService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing CleanUpService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing NotificationService” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2020-01-20T17:21:30+0500 lvl=info msg=“Backend rendering via phantomJS” logger=rendering
t=2020-01-20T17:21:30+0500 lvl=warn msg=“phantomJS is deprecated and will be removed in a future release. You should consider migrating from phantomJS to grafana-image-renderer plugin.” logger=rendering
t=2020-01-20T17:21:30+0500 lvl=info msg=“Initializing Stream Manager”
t=2020-01-20T17:21:30+0500 lvl=info msg=“HTTP Server Listen” logger=http.server address=[::]:8080 protocol=http subUrl= socket=
t=2020-01-20T17:23:29+0500 lvl=info msg=“Shutdown started” logger=server reason=“System signal: interrupt”
t=2020-01-20T17:23:29+0500 lvl=info msg=“Stopped UsageStatsService” logger=server reason=“context canceled”
t=2020-01-20T17:23:29+0500 lvl=info msg=“Stopped AlertEngine” logger=server reason=“context canceled”
t=2020-01-20T17:23:29+0500 lvl=info msg=“Stopped CleanUpService” logger=server reason=“context canceled”
t=2020-01-20T17:23:29+0500 lvl=info msg=“Stopped UserAuthTokenService” logger=server reason=“context canceled”
t=2020-01-20T17:23:29+0500 lvl=info msg=“Stopped Stream Manager”
t=2020-01-20T17:23:29+0500 lvl=info msg=“Stopped InternalMetricsService” logger=server reason=“context canceled”
t=2020-01-20T17:23:29+0500 lvl=info msg=“Stopped NotificationService” logger=server reason=“context canceled”
t=2020-01-20T17:23:29+0500 lvl=info msg=“Stopped PluginManager” logger=server reason=“context canceled”
t=2020-01-20T17:23:29+0500 lvl=info msg=“Stopped RemoteCache” logger=server reason=“context canceled”
t=2020-01-20T17:23:29+0500 lvl=info msg=“Stopped provisioningServiceImpl” logger=server reason=“context canceled”
t=2020-01-20T17:23:29+0500 lvl=eror msg=“Server shutdown” logger=server reason=nil
t=2020-01-20T17:23:49+0500 lvl=info msg=“Starting Grafana” logger=server version=6.5.2 commit=742d165 branch=HEAD compiled=2019-12-11T17:41:26+0500
t=2020-01-20T17:23:49+0500 lvl=info msg=“Config loaded from” logger=settings file=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2/conf/defaults.ini
t=2020-01-20T17:23:49+0500 lvl=info msg=“Config loaded from” logger=settings file=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\custom.ini
t=2020-01-20T17:23:49+0500 lvl=info msg=“Path Home” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2
t=2020-01-20T17:23:49+0500 lvl=info msg=“Path Data” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data
t=2020-01-20T17:23:49+0500 lvl=info msg=“Path Logs” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\log
t=2020-01-20T17:23:49+0500 lvl=info msg=“Path Plugins” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\data\plugins
t=2020-01-20T17:23:49+0500 lvl=info msg=“Path Provisioning” logger=settings path=D:\Grafana\grafana-6.5.2.windows-amd64\grafana-6.5.2\conf\provisioning
t=2020-01-20T17:23:49+0500 lvl=info msg=“App mode production” logger=settings
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing SqlStore” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Connecting to DB” logger=sqlstore dbtype=sqlite3
t=2020-01-20T17:23:49+0500 lvl=info msg=“Starting DB migration” logger=migrator
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing HTTPServer” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing OSSLicensingService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing SearchService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing RemoteCache” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing QuotaService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing ServerLockService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing UserAuthTokenService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing PluginManager” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Starting plugin search” logger=plugins
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing RenderingService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing AlertEngine” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing DatasourceCacheService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing HooksService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing LoginService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing InternalMetricsService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing TracingService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing UsageStatsService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing CleanUpService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing NotificationService” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing provisioningServiceImpl” logger=server
t=2020-01-20T17:23:49+0500 lvl=info msg=“Backend rendering via phantomJS” logger=rendering
t=2020-01-20T17:23:49+0500 lvl=warn msg=“phantomJS is deprecated and will be removed in a future release. You should consider migrating from phantomJS to grafana-image-renderer plugin.” logger=rendering
t=2020-01-20T17:23:49+0500 lvl=info msg=“Initializing Stream Manager”
t=2020-01-20T17:23:49+0500 lvl=info msg=“HTTP Server Listen” logger=http.server address=[::]:8080 protocol=http subUrl= socket=
Have you installed plugins there? Using grafana-cli or extracted zip files manually?
I still don’t see any debug log messages. Which is weird. Please copy sample.ini and name that custom.ini and then make your changes in that file.
Inspect browser developer tools results in console and network requests are
@anon34853223 I have done these changes in custom.ini as you said just copy sample.ini and then make changes
##################### Grafana Configuration Example #####################
# Everything has defaults so you only need to uncomment things you want to
# change
# possible values : production, development
;app_mode = production
# instance name, defaults to HOSTNAME environment variable value or hostname if HOSTNAME var is empty
;instance_name = ${HOSTNAME}
#################################### Paths ####################################
[paths]
# Path to where grafana can store temp files, sessions, and the sqlite3 db (if that is used)
;data = /var/lib/grafana
# Temporary files in `data` directory older than given duration will be removed
;temp_data_lifetime = 24h
# Directory where grafana can store logs
;logs = /var/log/grafana
# Directory where grafana will automatically scan and look for plugins
;plugins = /var/lib/grafana/plugins
# folder that contains provisioning config files that grafana will apply on startup and while running.
;provisioning = conf/provisioning
#################################### Server ####################################
[server]
# Protocol (http, https, h2, socket)
protocol = http
# The ip address to bind to, empty will bind to all interfaces
http_addr =
# The http port  to use
http_port = 8080
# The public facing domain name used to access grafana from a browser
;domain = localhost
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
;enforce_domain = false
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
;root_url = http://grafana.staged-by-discourse.com
# Serve Grafana from subpath specified in `root_url` setting. By default it is set to `false` for compatibility reasons.
;serve_from_sub_path = false
# Log web requests
;router_logging = false
# the path relative working path
;static_root_path = public
# enable gzip
;enable_gzip = false
# https certs & key file
;cert_file =
;cert_key =
# Unix socket path
;socket =
#################################### Database ####################################
[database]
# You can configure the database connection by specifying type, host, name, user and password
# as separate properties or as on string using the url properties.
# Either "mysql", "postgres" or "sqlite3", it's your choice
;type = sqlite3
;host = 127.0.0.1:3306
;name = grafana
;user = root
# If the password contains # or ; you have to wrap it with triple quotes. Ex """#password;"""
;password =
# Use either URL or the previous fields to configure the database
# Example: mysql://user:secret@host:port/database
;url =
# For "postgres" only, either "disable", "require" or "verify-full"
;ssl_mode = disable
# For "sqlite3" only, path relative to data_path setting
;path = grafana.db
# Max idle conn setting default is 2
;max_idle_conn = 2
# Max conn setting default is 0 (mean not set)
;max_open_conn =
# Connection Max Lifetime default is 14400 (means 14400 seconds or 4 hours)
;conn_max_lifetime = 14400
# Set to true to log the sql calls and execution times.
;log_queries =
# For "sqlite3" only. cache mode setting used for connecting to the database. (private, shared)
;cache_mode = private
#################################### Cache server #############################
[remote_cache]
# Either "redis", "memcached" or "database" default is "database"
;type = database
# cache connectionstring options
# database: will use Grafana primary database.
# redis: config like redis server e.g. `addr=127.0.0.1:6379,pool_size=100,db=0,ssl=false`. Only addr is required. ssl may be 'true', 'false', or 'insecure'.
# memcache: 127.0.0.1:11211
;connstr =
#################################### Data proxy ###########################
[dataproxy]
# This enables data proxy logging, default is false
;logging = false
# How long the data proxy should wait before timing out default is 30 (seconds)
;timeout = 30
# If enabled and user is not anonymous, data proxy will add X-Grafana-User header with username into the request, default is false.
;send_user_header = false
#################################### Analytics ####################################
[analytics]
# Server reporting, sends usage counters to stats.grafana.org every 24 hours.
# No ip addresses are being tracked, only simple counters to track
# running instances, dashboard and error counts. It is very helpful to us.
# Change this option to false to disable reporting.
;reporting_enabled = true
# Set to false to disable all checks to https://grafana.net
# for new vesions (grafana itself and plugins), check is used
# in some UI views to notify that grafana or plugin update exists
# This option does not cause any auto updates, nor send any information
# only a GET request to http://grafana.com to get latest versions
;check_for_updates = true
# Google Analytics universal tracking code, only enabled if you specify an id here
;google_analytics_ua_id =
# Google Tag Manager ID, only enabled if you specify an id here
;google_tag_manager_id =
#################################### Security ####################################
[security]
# disable creation of admin user on first start of grafana
;disable_initial_admin_creation = false
# default admin user, created on startup
;admin_user = admin
# default admin password, can be changed before first start of grafana,  or in profile settings
;admin_password = admin
# used for signing
;secret_key = SW2YcwTIb9zpOOhoPsMm
# disable gravatar profile images
;disable_gravatar = false
# data source proxy whitelist (ip_or_domain:port separated by spaces)
;data_source_proxy_whitelist =
# disable protection against brute force login attempts
;disable_brute_force_login_protection = false
# set to true if you host Grafana behind HTTPS. default is false.
;cookie_secure = false
# set cookie SameSite attribute. defaults to `lax`. can be set to "lax", "strict" and "none"
;cookie_samesite = lax
# set to true if you want to allow browsers to render Grafana in a <frame>, <iframe>, <embed> or <object>. default is false.
;allow_embedding = false
# Set to true if you want to enable http strict transport security (HSTS) response header.
# This is only sent when HTTPS is enabled in this configuration.
# HSTS tells browsers that the site should only be accessed using HTTPS.
# The default version will change to true in the next minor release, 6.3.
;strict_transport_security = false
# Sets how long a browser should cache HSTS. Only applied if strict_transport_security is enabled.
;strict_transport_security_max_age_seconds = 86400
# Set to true if to enable HSTS preloading option. Only applied if strict_transport_security is enabled.
;strict_transport_security_preload = false
# Set to true if to enable the HSTS includeSubDomains option. Only applied if strict_transport_security is enabled.
;strict_transport_security_subdomains = false
# Set to true to enable the X-Content-Type-Options response header.
# The X-Content-Type-Options response HTTP header is a marker used by the server to indicate that the MIME types advertised
# in the Content-Type headers should not be changed and be followed. The default will change to true in the next minor release, 6.3.
;x_content_type_options = false
# Set to true to enable the X-XSS-Protection header, which tells browsers to stop pages from loading
# when they detect reflected cross-site scripting (XSS) attacks. The default will change to true in the next minor release, 6.3.
;x_xss_protection = false
#################################### Snapshots ###########################
[snapshots]
# snapshot sharing options
;external_enabled = true
;external_snapshot_url = https://snapshots-origin.raintank.io
;external_snapshot_name = Publish to snapshot.raintank.io
# Set to true to enable this Grafana instance act as an external snapshot server and allow unauthenticated requests for
# creating and deleting snapshots.
;public_mode = false
# remove expired snapshot
;snapshot_remove_expired = true
#################################### Dashboards History ##################
[dashboards]
# Number dashboard versions to keep (per dashboard). Default: 20, Minimum: 1
;versions_to_keep = 20
#################################### Users ###############################
[users]
# disable user signup / registration
;allow_sign_up = true
# Allow non admin users to create organizations
;allow_org_create = true
# Set to true to automatically assign new users to the default organization (id 1)
;auto_assign_org = true
# Default role new users will be automatically assigned (if disabled above is set to true)
;auto_assign_org_role = Viewer
# Background text for the user field on the login page
;login_hint = email or username
;password_hint = password
# Default UI theme ("dark" or "light")
;default_theme = dark
# External user management, these options affect the organization users view
;external_manage_link_url =
;external_manage_link_name =
;external_manage_info =
# Viewers can edit/inspect dashboard settings in the browser. But not save the dashboard.
;viewers_can_edit = false
# Editors can administrate dashboard, folders and teams they create
;editors_can_admin = false
[auth]
# Login cookie name
;login_cookie_name = grafana_session
# The lifetime (days) an authenticated user can be inactive before being required to login at next visit. Default is 7 days,
;login_maximum_inactive_lifetime_days = 7
# The maximum lifetime (days) an authenticated user can be logged in since login time before being required to login. Default is 30 days.
;login_maximum_lifetime_days = 30
# How often should auth tokens be rotated for authenticated users when being active. The default is each 10 minutes.
;token_rotation_interval_minutes = 10
# Set to true to disable (hide) the login form, useful if you use OAuth, defaults to false
;disable_login_form = false
# Set to true to disable the signout link in the side menu. useful if you use auth.proxy, defaults to false
;disable_signout_menu = false
# URL to redirect the user to after sign out
;signout_redirect_url =
# Set to true to attempt login with OAuth automatically, skipping the login screen.
# This setting is ignored if multiple OAuth providers are configured.
;oauth_auto_login = false
#################################### Anonymous Auth ######################
[auth.anonymous]
# enable anonymous access
;enabled = false
# specify organization name that should be used for unauthenticated users
;org_name = Main Org.
# specify role for unauthenticated users
;org_role = Viewer
#################################### Github Auth ##########################
[auth.github]
;enabled = false
;client_id = some_id
;client_secret = some_secret
;scopes = user:email,read:org
;auth_url = https://github.com/login/oauth/authorize
;token_url = https://github.com/login/oauth/access_token
;api_url = https://api.github.com/user
;team_ids =
;allowed_organizations =
#################################### Google Auth ##########################
[auth.google]
;enabled = false
;client_id = some_client_id
;client_secret = some_client_secret
;scopes = https://www.googleapis.com/auth/userinfo.profile https://www.googleapis.com/auth/userinfo.email
;auth_url = https://accounts.google.com/o/oauth2/auth
;token_url = https://accounts.google.com/o/oauth2/token
;api_url = https://www.googleapis.com/oauth2/v1/userinfo
;allowed_domains =
#################################### Generic OAuth ##########################
[auth.generic_oauth]
;enabled = false
;name = OAuth
;email_attribute_name = email:primary
;email_attribute_path =
;auth_url = https://foo.bar/login/oauth/authorize
;token_url = https://foo.bar/login/oauth/access_token
;api_url = https://foo.bar/user
;team_ids =
;role_attribute_path =
;tls_skip_verify_insecure = false
;tls_client_cert =
;tls_client_key =
;tls_client_ca =
; Set to true to enable sending client_id and client_secret via POST body instead of Basic authentication HTTP header
; This might be required if the OAuth provider is not RFC6749 compliant, only supporting credentials passed via POST payload
;send_client_credentials_via_post = false
#################################### SAML Auth ###########################
[auth.saml] # Enterprise only
# Defaults to false. If true, the feature is enabled.
;enabled = false
# Base64-encoded public X.509 certificate. Used to sign requests to the IdP
;certificate =
# Path to the public X.509 certificate. Used to sign requests to the IdP
;certificate_path =
# Base64-encoded private key. Used to decrypt assertions from the IdP
;private_key =
;# Path to the private key. Used to decrypt assertions from the IdP
;private_key_path =
# Base64-encoded IdP SAML metadata XML. Used to verify and obtain binding locations from the IdP
;idp_metadata =
# Path to the SAML metadata XML. Used to verify and obtain binding locations from the IdP
;idp_metadata_path =
# URL to fetch SAML IdP metadata. Used to verify and obtain binding locations from the IdP
;idp_metadata_url =
# Duration, since the IdP issued a response and the SP is allowed to process it. Defaults to 90 seconds.
;max_issue_delay = 90s
# Duration, for how long the SP's metadata should be valid. Defaults to 48 hours.
;metadata_valid_duration = 48h
# Friendly name or name of the attribute within the SAML assertion to use as the user's name
;assertion_attribute_name = displayName
# Friendly name or name of the attribute within the SAML assertion to use as the user's login handle
;assertion_attribute_login = mail
# Friendly name or name of the attribute within the SAML assertion to use as the user's email
;assertion_attribute_email = mail
#################################### Grafana.com Auth ####################
[auth.grafana_com]
;enabled = false
#################################### Auth Proxy ##########################
[auth.proxy]
;enabled = false
;header_name = X-WEBAUTH-USER
;header_property = username
;auto_sign_up = true
;sync_ttl = 60
;whitelist = 192.168.1.1, 192.168.2.1
;headers = Email:X-User-Email, Name:X-User-Name
# Read the auth proxy docs for details on what the setting below enables
;enable_login_token = false
#################################### Basic Auth ##########################
[auth.basic]
;enabled = true
#################################### Auth LDAP ##########################
[auth.ldap]
;enabled = false
;config_file = /etc/grafana/ldap.toml
# LDAP backround sync (Enterprise only)
# At 1 am every day
;sync_cron = "0 0 1 * * *"
;active_sync_enabled = true
#################################### SMTP / Emailing ##########################
[smtp]
;enabled = false
;host = localhost:25
;user =
;password =
;cert_file =
;key_file =
;skip_verify = false
;from_address = admin@grafana.localhost
;from_name = Grafana
# EHLO identity in SMTP dialog (defaults to instance_name)
;ehlo_identity = dashboard.example.com
[emails]
;welcome_email_on_sign_up = false
#################################### Logging ##########################
[log]
# Either "console", "file", "syslog". Default is console and  file
# Use space to separate multiple modes, e.g. "console file"
mode = console file
# Either "debug", "info", "warn", "error", "critical", default is "info"
level = debug
# optional settings to set different levels for specific loggers. Ex filters = sqlstore:debug
filters =sqlstore:debug
# For "console" mode only
[log.console]
;level =
# log line format, valid options are text, console and json
;format = console
# For "file" mode only
[log.file]
;level =
;format = text
# This enables automated log rotate(switch of following options), default is true
;log_rotate = true
# Max line number of single file, default is 1000000
;max_lines = 1000000
# Max size shift of single file, default is 28 means 1 << 28, 256MB
;max_size_shift = 28
# Segment log daily, default is true
;daily_rotate = true
# Expired days of log file(delete after max days), default is 7
;max_days = 7
[log.syslog]
;level =
;format = text
# Syslog network type and address. This can be udp, tcp, or unix. If left blank, the default unix endpoints will be used.
;network =
;address =
# Syslog facility. user, daemon and local0 through local7 are valid.
;facility =
# Syslog tag. By default, the process' argv[0] is used.
;tag =
#################################### Alerting ############################
[alerting]
# Disable alerting engine & UI features
;enabled = true
# Makes it possible to turn off alert rule execution but alerting UI is visible
;execute_alerts = true
# Default setting for new alert rules. Defaults to categorize error and timeouts as alerting. (alerting, keep_state)
;error_or_timeout = alerting
# Default setting for how Grafana handles nodata or null values in alerting. (alerting, no_data, keep_state, ok)
;nodata_or_nullvalues = no_data
# Alert notifications can include images, but rendering many images at the same time can overload the server
# This limit will protect the server from render overloading and make sure notifications are sent out quickly
;concurrent_render_limit = 5
# Default setting for alert calculation timeout. Default value is 30
;evaluation_timeout_seconds = 30
# Default setting for alert notification timeout. Default value is 30
;notification_timeout_seconds = 30
# Default setting for max attempts to sending alert notifications. Default value is 3
;max_attempts = 3
#################################### Explore #############################
[explore]
# Enable the Explore section
;enabled = true
#################################### Internal Grafana Metrics ##########################
# Metrics available at HTTP API Url /metrics
[metrics]
# Disable / Enable internal metrics
;enabled           = true
# Disable total stats (stat_totals_*) metrics to be generated
;disable_total_stats = false
# Publish interval
;interval_seconds  = 10
# Send internal metrics to Graphite
[metrics.graphite]
# Enable by setting the address setting (ex localhost:2003)
;address =
;prefix = prod.grafana.%(instance_name)s.
#################################### Distributed tracing ############
[tracing.jaeger]
# Enable by setting the address sending traces to jaeger (ex localhost:6831)
;address = localhost:6831
# Tag that will always be included in when creating new spans. ex (tag1:value1,tag2:value2)
;always_included_tag = tag1:value1
# Type specifies the type of the sampler: const, probabilistic, rateLimiting, or remote
;sampler_type = const
# jaeger samplerconfig param
# for "const" sampler, 0 or 1 for always false/true respectively
# for "probabilistic" sampler, a probability between 0 and 1
# for "rateLimiting" sampler, the number of spans per second
# for "remote" sampler, param is the same as for "probabilistic"
# and indicates the initial sampling rate before the actual one
# is received from the mothership
;sampler_param = 1
# Whether or not to use Zipkin propagation (x-b3- HTTP headers).
;zipkin_propagation = false
# Setting this to true disables shared RPC spans.
# Not disabling is the most common setting when using Zipkin elsewhere in your infrastructure.
;disable_shared_zipkin_spans = false
#################################### Grafana.com integration  ##########################
# Url used to import dashboards directly from Grafana.com
[grafana_com]
;url = https://grafana.com
#################################### External image storage ##########################
[external_image_storage]
# Used for uploading images to public servers so they can be included in slack/email messages.
# you can choose between (s3, webdav, gcs, azure_blob, local)
;provider =
[external_image_storage.s3]
;bucket =
;region =
;path =
;access_key =
;secret_key =
[external_image_storage.webdav]
;url =
;public_url =
;username =
;password =
[external_image_storage.gcs]
;key_file =
;bucket =
;path =
[external_image_storage.azure_blob]
;account_name =
;account_key =
;container_name =
[external_image_storage.local]
# does not require any configuration
[rendering]
# Options to configure a remote HTTP image rendering service, e.g. using https://github.com/grafana/grafana-image-renderer.
# URL to a remote HTTP image renderer service, e.g. http://localhost:8081/render, will enable Grafana to render panels and dashboards to PNG-images using HTTP requests to an external service.
;server_url =
# If the remote HTTP image renderer service runs on a different server than the Grafana server you may have to configure this to a URL where Grafana is reachable, e.g. http://grafana.domain/.
;callback_url =
[enterprise]
# Path to a valid Grafana Enterprise license.jwt file
;license_path =
[panels]
# If set to true Grafana will allow script tags in text panels. Not recommended as it enable XSS vulnerabilities.
;disable_sanitize_html = false
[plugins]
;enable_alpha = false
;app_tls_skip_verify_insecure = false
And what does the log output look like when you stop and start grafana process now?
You’re running Grafana as a Windows service, right? Make sure that the user account running that Windows service have permission to read your plugins folder and the plugins.
To remove one possible problem I would recommend you to start the grafana.exe manually from command prompt since then it will run using your user. Then see if you get the plugins. If so, you definitely have a problem with the user account running your Windows service.
The problem was releated to mixing up install directories and configuration between different drives (C: and D:\)
Thank you so much for the help @anon34853223 & @anon349787 . Issue has been resolved. Now, I am closing this issue.
Can you elaborate this , i am facing same issue . I followed the steps till here but did’nt seem to work.!
@anon34853223
