Grafana plugins not visible
I have previously installed plugins to my grafana instance - these have for some reason disappeared - i have re-downloaded them using grafana-cli and the installation appears successful - i have then restarted grafana-server and performed a system reboot - even after taking these steps any plugin i try and install does not appear.
I have logged in as root and performed a
chown -R grafana:grafana /var/lib/grafana/plugins -R
just incase the ownership has changed as mentioned in a post i had seen with a similar issue. I still cannot see any of the installed plugins,
Grafana v6.4.2 (commit: 443a0ba)
Any help greatly appreciated
**SOLVED
For some reason a rogue dist folder was in the plugins directory - im guessing this had confused the plugin service and was stopping all plugins from being visible. Renamed the dist folder and all appears to now be working.
Cheers/
