GRAFANA FORUM’S 3 BEST PRACTICES:
What Grafana version and what operating system are you using? (V8.5.4)
(To make a time series panel) -
(Creating new panel Set
From to logs
Time colum to timestamp
Select to colum rwwc -
What happened?
Shows my data but with the wrong time about 4 hours earlier then my database time -
For my time stamp in my mysql would be same as on grafana -
Not sure when there a -4 on the timestamp. And even if I change it here
My life feed never right.
I’m at a lost
