hey guys. Im new to this. Im using raspberry pi for my webcam face detection project. The face detection also count the face. How can i add the count into grafana? and i already install grafan and influxdb on my raspberry pi.
Have you already got the data into influx?
Not yet. Still doing more research. Do u hve any tips?
Use node-red. Then it is easy.
Haaa okay. Will do. Thnk u
already tried the node red but stuck at the input symbol. didnt know which one to use
Ask on the node-red forum, which is usually very helpful. A number there use Influx with Grafana.
okay. thnk u for the help
IF you are familiar with Python programming you can use the following article. I had used it and worked pretty well. This exactly explains how to get data into influx database with a sample code.
https://www.influxdata.com/blog/getting-started-python-influxdb/
