8.3.2
Modification of alert messages trough templating.
The Alert gets send to my OpsGenie Account. -
Created an Alert Rule and then in the “Contact Points” Tab some templates to customize
the message.
The alert is firing correctly and is also sent to the OpsGenie but it never uses the templates.
- What happened?
It seems to have absolutey no effect on the notification that is getting sent out it is always
the default template e.g:
The templates i’ve created to have any actual effect.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No - Did you follow any online instructions? If so, what is the URL?
tried to follow: Notification templating | Grafana documentation and also have some examples in use there.
