Using grafana 8.3.2 as a docker container (Ubuntu)
Older versions are affected as well -
I’m trying to use custom templates to have more simple notifications when an alert fires. I’m just interested in the the dashboard/panelURL. -
Setting a custom template for grafana managed alerts -
What happened?
I get a mail with the status of the alert, but not the dashboard or panel URL (even though they work with the default template)
A mail containing the pannel and dashboard URL -
{{ define “experimentaltemplate” }}
Status : {{.Status}}
Dashboard : {{.DashboardURL}}
Panel : {{.PanelURL}}
{{ end }} -
No error in Grafana UI or logs, the logs said that the notification is sent successfully. -
The official documentation regarding alerts templates.
I just responded to another post with the same question I would have posted here. The site will not allow me to post the same thing. Take a look at my response here:
