grafana playground
- What are you trying to achieve?
not rounded negative decimal numbers
- How are you trying to achieve it?
- What happened?
the value gets rounded
see exact value
- Can you copy/paste the configuration(s) that you are having problems with?
grafana play
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
no errors
- Possible BUG
grafana/valueFormats.test.ts at 2107652c3fdeebf499c360795c219f68ef47b65f · grafana/grafana · GitHub
or,
grafana/valueFormats.ts at 2107652c3fdeebf499c360795c219f68ef47b65f · grafana/grafana · GitHub
