Version: Grafana v7.1.0-beta1 (4d1ea72426)
OS: Windows 10 Pro -
I want to show a negative decimal value on table with formating number: Unit > Locale Format -
- I create a table and put my query to it.
- I change the format number to locale format by:
- go to overides
- chose field > add overides properties > unit > Misc > locale format
What happened?
Grafana give me error message : “maximumFractionDigits value is out of range” -
I’m not expect this error happen, I want to show my data with locale format even the value is negative decimal
