Grafana 3.3.3
Windows 10, German locale
The numbers in the datasource are English locale -
Displaying numbers correctly in a dashboard panel -
Finding a configuration to switch locales -
What happened?
Displaying values like 32.9 as 329 on x-axis
32.9 being 32.9 or 32,9 but not take it times 10
Not sure if it works for your Grafana version, but you have to set Standard options->Unit. Set it to locale format.
Does not change anything.
