xanthi
December 13, 2023, 12:28pm
1
Hello
I am trying to follow the tutorial on GitHub - FIWARE/tutorials.Time-Series-Data: π FIWARE 304: Querying Time Series Data (QuantumLeap) . I am stuck at the point that says:
"Click on Visualizations tab on the left and set as follows:
Map Layers:
Lamp:
Icon: lightbulb-o
ClusterType: average
ColorType: fix
Column for value: value
Maker color: red
I canβt find these settings because I guess the document was created with an older version of Grafana.
Thank you in advance
Sakis
yosiasz
December 13, 2023, 1:34pm
2
Welcome @xanthi
What is your datasource? Createdb or something else?
Can you post some sample data text here?
xanthi
December 13, 2023, 2:40pm
3
Hello and thanks for the quick reply!
The data source is CrateDB. Sample data you can find on this link:
https://github.com/FIWARE/tutorials.Time-Series-Data/blob/master/import-data
Regards
Sakis
yosiasz
December 13, 2023, 3:02pm
4
I would use infinity plugin with UQL and jsonata to extract the data and map it
https://try.jsonata.org/A0mwsHPkn
yosiasz
December 13, 2023, 4:18pm
5
but since you will probably query the cratedb database you should use Orchestra City plugin
with das_pretzels as (
select unnest(store_details['entities'] ) as obj
from berliner
select obj['name']['value'] as name
,obj['location']['value']['coordinates'][1] as lon
,obj['location']['value']['coordinates'][2] as lat
from das_pretzels;
xanthi
December 14, 2023, 2:02pm
6
Well, I managed to show the spots on the map with the Orchestra City plugin. So thanks a lot for your help!
