Hello community,
Can anyone help me to onboard into grafana dashboards. I have hosted the grafana in docker. I need a grafana backup json files with northwind database.
Latest, linux and docker -
Need to visualize the sql data in dashboard. -
By adding a data source - What happened?
Since new to grafana, need a backup json. - What did you expect to happen?
Backup files - Can you copy/paste the configuration(s) that you are having problems with?
NA - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
NA - Did you follow any online instructions? If so, what is the URL?
NO.
