version": “7.5.3” -
Plot time-series with Metric as IPv4 address and Value as a Count (int)
Query -
SELECT
UNIX_TIMESTAMP() as time,
ipv4_addr as metric,
total_hits as value
FROM
Table_A
ORDER BY “time” ASC
I created a time-series dashboard. Configured Mysql data source and issued the above query. -
What happened?
The query returns 100 data points; I see 100 dots on the graph vertically in the same line at the rightmost end of the graph. Line graph is not plotted and is not moving. It looks like below
A proper line graph to be plotted instead of single dot for every data point -
Query -
SELECT
total_hits as value
FROM
Table_A
ORDER BY “time” ASC -
No errors -
No
