Mysql data source unusable with Grafana cloud
The Mysql data source doesn’t work with grafana cloud.
I am using identical settings as what i use to test with my local grafana instance but it fails with “Failed to update datasource” No additional feedback.
Also the form is likely unnecessarily clunky for Mysql
So i am force to set “TLS/SSL Root Certificate” which i do on both sides.
Where is the mysql server located and how are you creating the datasource?
Mysql is a planetscale instance, planetscale.com, located in Singapore
To create the data source i went to the UI and filled the form:
Host
database
Username
Passwort
Ticked With CA Cert
Entered the same TLS/SSL Root certificate as my machine.
I tried to follow Planetscale blog for common SSL erros, and used the Mozilla provided CA to no avail
Then when clicking “Save & Test” I see that error.
Is there any way to see more about what the error is like i can do when there is an error on my local Grafana instance?
EDIT: After finding that blog post, i scrolled through the whole content
Support’s notes from the field following this and pasting the let’s encrypt provided CA certificate worked! Resolved
