How to connect Grafana with a Google Cloud MySQL?
Hi!
New to Grafana here and I want to connect it with a MySQL. The db is a Google Cloud MySQL.
I have tried all variations of values in the native connector (In the Grafana GUI) and I always get connection refused. I believe the issue is with the connection configuration on Google Cloud.
I have searched all over for how to accomplish this without success. I’m not experienced with databases, docker and grafana so I lack the high level overview.
Can anyone advise me on how to configure the connection? Do I use SSL, CA’s, public or private IP?
Thank you!
@havmuggerud can you clarify which version of Grafana you’re using and which Grafana data source you’re trying to connect with (Google Cloud Monitoring or MySQL)?
Hi @samcoren!
I’m on Grafana v7.1.5 and I’m trying to connect with MySQL.
I am trying to do the same thing… did you get it working?
I am using Grafana cloud service, trying to get data out of a google cloud mysql database. I cant seem to find a guide. The database has a public IP which allows me to write into from my home network, but I cant find a guide on how to integrate Grafana to Google.
