Hi, I am trying to connect to mariaDB secured by certificate. I am sure that the database is correctly configured, but when I try to pass client certificate and key to grafana for the connection always give me the following log:
logger=tsdb.mysql t=2024-04-09T10:41:36.87+0200 lvl=eror msg=“query error” err=“remote error: tls: handshake failure”
I am using:
- Grafana version 8.4.4
- MariaDB version 15.1 Distrib 10.7.5-MariaDB
This is the configuration I am using:
- /etc/grafana/provisioning/datasource/file.yaml :
apiVersion: 1
deleteDatasources:
- name: MySQL-SSL
orgId: 1
datasources:
- name: MySQL-SSL
type: mysql
url: 127.0.0.1:3306
user: user
database: DB_TEST
jsonData:
tlsAuth: true
tlsAuthWithCACert: false
tlsSkipVerify: true
secureJsonData:
tlsClientCert: $__file{/cert/client-cert.pem}
tlsClientKey: $__file{/cert/client-key.pem}
password: ***
editable: false
- /etc/mariadb/server.cnf
[mysqld]
require_secure_transport = ON
bind-address = 0.0.0.0
ssl-ca=/cert/ca-cert.pem
ssl-cert=/cert/server-cert.pem
ssl-key=/cert/server-key.pem
tls_version=TLSv1.2,TLSv1.3
ssl-cipher=DHE-RSA-AES256-SHA
I configure the same certificate with DBeaver and the connection is established with success. The only difference between Grafana and DBeaver is “requireSSL”.
Do you known how can I create a connection like this? I have to update Grafana version?
Thanks
