MySQL data collection from locally hosted data
    Grafana cloud and Mac
    Setup data collection
    By configuring through the UI
  • What happened?
    failed to connect to server - please inspect Grafana server log for details
    As the agent has been successfully installed and the connection successfully tested, data collection would be straight forward
    Just the standard setup via the UI
    There is no errors in the grafana-agent.err.log file & there is nothing at all in the grafana-agent.log file
    MySQL data source | Grafana documentation
Where is the mysql server located at in relation to grafana cloud
It’s located locally on my Mac, running on bare metal
How are you referring this local mysql in your connection from cloud grafana? Via a public ip address?
sorry, i’ve worked out my issue. I didn’t want to open my db up to the internet & misunderstood the documentation. I’ve just realised I can install Grafana locally and am now unblocked. thank you for answering my enquiry
