My published dashboard doesnot show in Grafana dashboards
  • What Grafana version and what operating system are you using? Im using the latest version of Grafana
  • What are you trying to achieve? I have built a new dashboard of Airflow 3. I intent to public it for community.
  • How are you trying to achieve it? I have no idea to public it. I got stuck at the step after I publice in cuongvothanh Dashboards | Grafana Labs
  • What happened? but when I submit the dashboard, publiceit does not appear on main page, even it returns id 24832 (Airflow 3 | Grafana Labs)
  • What did you expect to happen? It should be appeared in mainpage that everyone could use it.
  • Can you copy/paste the configuration(s) that you are having problems with? it does not appearhttps://grafana.com/grafana/dashboards/24832
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. Nah I dont receive any issue
  • Did you follow any online instructions? If so, what is the URL? N/A
It depends what is “main page”. I see it now Grafana dashboards | Grafana Labs
New published dashboards are not available for other users immediately. It needs a few hours usually.
