We’ve multiple set of prometheus instances(2 prometheus per set) running for monitoring different services. We’ve a shared grafana cluster (3 instances with a mysql db).
I am planning to set a loadbalancer infront of these prometheus & then use the loadbalancer as the datasource endpoint.
Will there be any issue when the requests (from grafana to prometheus) will be load balanced ?
PS : I tried to search related discussion but didn’t get any answer on this.
Also, new to grafana so not sure on how to use datasource template variable (as shared here Recommended HA setup)
Also, we;ve all the setup running on aws ec2.
