I try to provision a grafana instgance with a datasource from prometheus. I use this
apiVersion: 1
datasources:
- name: <%= @source_name %>
type: Prometheus
access: direct
orgId: 1
url: http://localhost:9090
isDefault: true
version: 1
editable: false
but even if it create the datasource, the information are not saved properly. Did I miss something?
I have the version 5.0.3 of grafana
thanks
Should be a lower-case p: prometheus
Does the name look right in Grafana? Not sure what tool you are using here.
Are you sure you want a direct connection to your Prometheus instance? Most of the time you should be using proxy mode.
I forget to replace the “<%= @source_name %>”, it’s my template of chef
the value in the server is
apiVersion: 1
datasources:
- name: prometheusdata
type: Prometheus
access: direct
orgId: 1
isDefault: true
version: 1
editable: false
thanks for the help, I will try later and give my feedback
Well even by replacing the Prometheus by “prometheus” I have the exact same behaviour
Did you restart Grafana after changing the file? Datasource files are only read on startup.
yes, (it’s builded by chef)
I don’t know - it worked for me. I took your file and the only change I made was to make the type field lowercase.
Just to double check you changed the type field to be lowercase and not any other field?
Can you also check if you have created multiple data sources? Maybe you changed the name and got a new data source?
Sidenote: This blog post is good intro to provisioning: https://medium.com/56kcloud/provisioning-grafana-data-sources-and-dashboards-auto-magically-e27155d20652
Adding a datasource (or edit it) is ok, it’s just the provisioning that doesn’t work properly.
So this is what I did:
- Created a new file called prom.yaml in the
conf/provisioning/datasources directory.
- Pasted the following text into it:
apiVersion: 1
datasources:
type: prometheus
access: direct
orgId: 1
isDefault: true
version: 1
editable: false
- Restarted Grafana
In my logs, I got this line:
INFO[03-23|15:23:15] inserting datasource from configuration logger=provisioning.datasources name=prometheusdata
And in data sources:
Are you doing something different (with Chef in your case)?
well finally it works, strange
thanks for the help
