After rewriting my plugin as an backend plugin, mouse hoovering the graph will either show the last or the first entry, but never all the middle points. If i enable “Points” under display, so it is easier to see if what the mouse is over, I can see that if I move mouse mouse to the left half, it show the value from the far right,
if I move my mouse the right half, it show the value from the far left.
I never really understod the “data.NewFrame” part in the go code, so i trie creating a frame per point instead of a frame per dataset, that “kind of” works except now grafana cant figure out to correlate each target
Can anyone “spot” the error ? Am i creating the data frames wrongly or is grafana 7.4 broken when using backend plugins ? ( I create a graph using Prometheus or my old add it works perfectly fine so must be either a “backend plugin” thing or “my code” thing, most likely something my code . )
