What Grafana version and what operating system are you using? 12.3.1
What are you trying to achieve? Compare the values of a metric in a timeseries view with the same metric values of 1 day before.
How are you trying to achieve it? I created a Time Series visualization with two queries for the same metric. For the second query, I added the function timeShift to show the values of the -24h.
What happened? It works, but the Legend reports the same name, the name of the Zabbix metric, and it’s impossible to distinguish between the current graph and the past graph.
What did you expect to happen? A way to modify the name of the series.
in your query can you modify the metric to show current and past? In the Item field
Hi @albertocoopkg
You can use Alias, maybe Set Alias or ReplaceAlias with regex.
