Missing values in bar chart
Hello everyone,
I’m currently working with a graph and have encountered a minor issue.
Despite having the “Show values: always” setting, I’m facing a situation where the count is not displayed in each bar chart.
When I apply a result limit to the query, the labels on the graph are correctly displayed.
I would greatly appreciate it if someone could provide some insight or guidance on resolving this matter.
Thank you in advance for your time and assistance.
Kind regards,
Vasiliki
I have the same problem. Show values: always not displaying the values.
Anyone that has the same issue here? Or someone that accomplished to solve it?
I have exacly the same behaviour. Show Values: Always does also only show values when you zoom into the bar chart and there is a samll number of bars.
I’m running Grafana v10.0.3 (eb8dd72637).
I am also the same issue. When attempting to retrieve data from the past 2 to 3 days or the last 7 days, the numbers are displayed on the bars. However, when trying to retrieve data from the past year or month, the numbers are not displayed. It’s possible that the issue arises when there is a larger volume of data, preventing the numbers from being displayed.
I found this workaround to set the text size manually:
cheers
