We send the prometheus metrics from our application to Grafana SaaS Cloud instance -
On the Grafana Cloud dashboard we setup the retrieved data line is too long (please see below) and its not possible to see the most important metrics which are the “qmgr” and “queue”. We had to painfully copy the entire retrieved string below which you can see when you hover mouse over the graph.
The display ordering we think Grafana decides to format/sort a map: it appears to be alphabetic. But it’s certainly not the same order in which the labels were added
Please suggest a way to fix it.
How it is today:
ibmmq_queue_mqput_mqput1_count{description=“-”, endpoint=“metrics”, instance=“10.131.0.244:9157”, job=“mq-metric-service-qmgr04”, namespace=“mq”, platform=“UNIX”, pod=“mq-metric-qmgr04-f549b4684-wghww”, prometheus=“openshift-user-workload-monitoring/user-workload”, prometheus_replica=“prometheus-user-workload-1”, qmgr=“QMGR04”, queue=“TIP230.HEALTHCHECK”, service=“mq-metric-service-qmgr04”, usage=“NORMAL”}
How it should be:
ibmmq_queue_mqput_mqput1_count{qmgr=“QMGR04”, queue=“TIP230.HEALTHCHECK”, description=“-”, endpoint=“metrics”, instance=“10.131.0.244:9157”, job=“mq-metric-service-qmgr04”, namespace=“mq”, platform=“UNIX”, pod=“mq-metric-qmgr04-f549b4684-wghww”, prometheus=“openshift-user-workload-monitoring/user-workload”, prometheus_replica=“prometheus-user-workload-1”, service=“mq-metric-service-qmgr04”, usage=“NORMAL”}
Environment (with versions):
- Grafana version: Whatever is your latest on grafana cloud
- Operating system: RHEL
- Datasource version(s) (prometheus, graphite, etc.): Built-in Prometheus instance on Openshift cluster
