What Grafana version and what operating system are you using? - v7.5.4
What are you trying to achieve? -Hello, I am new to Grafana and I have a promql query that basically returns the number free disk space of a kubernetes Nodes. The promql query returns the results, however its returns in time series. I wanted to merge same value(in my case instance) to be just unique in one row.
I am using Transform >> Outer join and then merge and but it is not working.
Promql that I used:
100 - (100 * ((node_filesystem_avail_bytes{mountpoint="/",fstype!="rootfs"} ) / (node_filesystem_size_bytes{mountpoint="/",fstype!="rootfs"}) ))
Please attached screenshot.
Thanks in advance!
