Math expression not working properly
I am trying to get the difference between first and last value of a query, and I tried to get by to different querys. I get in two different querys the values and tried to do a math expression that doesn’t seems to work properly, and I don’t understand why
Anyone could help me understanding how can I get the desired result?
welcome @antoniomanuelcadiz
Check out this function that can do the same
It does not work or a Im missing something? The following screenshots may help you and me
The value bellow 1 is the goal for me, for having more context
Following there is the query I tried
Remove time grouping from the query
Okey, thanks for the explanation, I tried your tip, removing that element make it works!
Thank you, and I hope that the wiki about functions would’ve more examples and a more clarify explanation
