Marcusolsson-csv-datasource plugin brings "Handle is invalid"
Hi there, I am using marcusolsson-csv-datasource plugin on a windows machine. I already got grafana local installed and also handled the plugin installation, local mode allowed and data path on windows. But now I get the reply “The handle is invalid” when trying to define the query. What is wrong and how can I fix it?
Welcome
Please share you csv data source configuration in grafana?
Thank you for you question. I just found the problem. I was under the impression, that configuring the data source would be enough and I would not need to choose file by itself. After adding the file name in the path tab everything works just fine.
