CSV as data source on Windows
This is a re-run of a closed topic from Jul 20. However it was not clear from the thread what the ‘workround’ was to resolve the problem. The conversations was with Paval (the CSV plugin author) and a new user with the following error trying to add a local csv data source.
I have already added:
‘[plugin.marcusolsson-csv-datasource]
allow_local_mode = true’
To the config.ini file.
Hey! I’m the author of the CSV data source you’re using. Unfortunately, the plugin doesn’t support Windows style path separators yet. Here’s the related GitHub issue.
For now, I think you should be able to fix it by using forward-slashes instead.
Hi. That is brilliant. It worked straight away. Thanks very much for your help. Cheers jules
