Error with csv data source plugin installation
Grafana oss running on docker
    i want to install csv data source plugin
    grafana-cli plugins install marcusolsson-csv-datasource
  • What happened?
Error: ✗ Get “https://grafana.com/api/plugins/marcusolsson-csv-datasource/versions”: context deadline exceeded (Client.Timeout exceeded while awaiting headers)
anyone faced this isssue and can share their experience?
The CSV plugin you’re using is deprecated and should be avoided; outside of security related issues further releases with new functionality will not be published.
Use the Infinity plugin instead for visualizing CSV. Details here:
