Grafana Version = 8.4.7 - What are you trying to achieve?
I am trying to access a CSV datasource from Grafana using nixOS - How are you trying to achieve it?
I installed CSV plugin. I added a CSV datasource and provided http url .
I clicked Save&Test - What happened?
It failed with “Plugin unavailable” error - What did you expect to happen?
The datasource should be valid and available - Can you copy/paste the configuration(s) that you are having problems with?
Grafana Version = v8.4.7 - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Yes.
On Grafana UI , when I click on theSave&Test it shows
