Grafana will not start after install
It pulls the package fine but when starting it errors out
Error: ✗ Get “https://grafana.com/api/plugins/grafana-clock-panel/versions”: context deadline exceeded (Client.Timeout exceeded while awaiting headers)
When I got to the actual Website I am able to hit it.
In Docker Portainer I get this error"
Stopped for 1 minute with exit code 1
  • Did you follow any online instructions? If so, what is the URL? I checked to see if there was an outage and There is none reported today. There was one yesterday
Are you trying to install Grafana or the clock panel plugin?
I’m having the same issue just after installing the plugin. Any ideas why this is happening ?
Hey @lorry96
Same question: are you trying to install Grafana or the clock panel?
hi, i was trying to install plugin. For context, i installed Grafana as docker image and this issue happened. As a workaround , i installed grafana standalone and then installed plugin. It worked like a charm
Hey @lorry96
Can you show how you installed the plugin please?
Hi, here is what i used:
Go to : /usr/share/grafana/bin
sudo ./grafana cli plugins install <plugin_id>
Exemple:
Sudo ./grafana cli plugins install marcusolsson-csv-datasource
Which plugin_id did you put?
Also, can you make sure your server have an Internet acces?
Hi, i used csv plugin as plugin_id. With docker image i think the issue was related to proxy / FW rules (i’m in corporate enviornment) . Switching to standalone version solved the issue. I was able to install plugins and grafana started normally. Everything is working right now. Thanks for your help
You can add proxy settings in the compose.yaml:
environment:
  GF_INSTALL_PLUGINS: alexanderzobnin-zabbix-app
  HTTP_PROXY: http://<proxy_ip>:8080
  HTTPS_PROXY: http://<proxy_ip>:8080
  NO_PROXY: localhost,127.0.0.1,172.16.0.0/12
Grafana can start with the HTTP/HTTPS proxy settings, but the packets between the Grafana and Zabbix containers will be sent through the proxy. In this case I got 403 Forbidden, because the proxy blocked these messages.
The solution is to set the NO_PROXY with the internal subnets (at least with the Zabbix webserver IP) to have direct connection between them.
