Hello guys!
I’m from Brazil and I’m sorry for my English.
I created a container with Grafana in Docker and in the first few days it worked perfectly, but in a few days it has presented me with an error:
Plugin Error
(SystemJS) XHR error (403 Forbidden) loading http://192.168.40.6:3000/public/plugins/alexanderzobnin-zabbix-app/datasource-zabbix/zabbixCachingProxy.service.js?bust=1508871186189
Error: XHR error (403 Forbidden) loading http://192.168.40.6:3000/public/plugins/alexanderzobnin-zabbix-app/datasource-zabbix/zabbixCachingProxy.service.js?bust=1508871186189
Error loading http://192.168.40.6:3000/public/plugins/alexanderzobnin-zabbix-app/datasource-zabbix/zabbixCachingProxy.service.js as “./zabbixCachingProxy.service.js” from http://192.168.40.6: 3000 / public / plugins / alexanderzobnin-zabbix-app / datasource-zabbix / zabbix.js
Does anyone know what it is or how to solve it?
Strange. How did you install the Zabbix plugin? Did you use the env variable -e "GF_INSTALL_PLUGINS=... (see here).
Yes, I did like this:
docker run -d --name=grafana --hostname=grafana
-v /etc/timezone:/etc/timezone -v /var/lib/grafana/:/var/lib/grafana/
-e “GF_SECURITY_ADMIN_PASSWORD = ***********”
-e “GF_INSTALL_PLUGINS = foursquare-clouderamanager-datasource”
-e “GF_INSTALL_PLUGINS = grafana-clock-panel, grafana-simple-json-datasource”
-e “GF_INSTALL_PLUGINS = alexanderzobnin-zabbix-app”
-p 3000:3000 grafana/grafana
Delete the /var/lib/grafana directory and re-create it by giving 777 permission.
It sounds like this bug but I’m not sure why you would be seeing it: https://github.com/grafana/grafana/issues/9509
Is it only the zabbix plugin that does not work?
Yes, just the Zabbix plugin.
At first everything was OK, this error appeared from a few days to ago. It worked for a month practically.
Have you tried stop/starting the docker container (that does an automatic update if there is a new version). Or even rebuilding the container from scratch:
docker pull grafana/grafana
docker stop grafana
docker rm grafana
and then your docker run command again.
I managed to find the problem. The Zabbix plugin was being barred by the proxy. I did not quite understand why, but I released his access and it worked again.
Thanks for the help ^^
