Hi All,
I am using the linux server for the grafana setup on the Virtual Machines(VM). But my VMs are not exposed to the internet. So i have used the rpm packages for installation. Now I have downloaded the status panel and pie chart plugins and installed through the rpm method. I could see the plugins are installed in the server and not populating in the web console. What should I do now. Can anyone help me on this??. Currently I am using the grafana version 6.7.
Did you restart the Grafana service? If you did, any errors in your Grafana server logs? If it failed to load them, then there should be errors.
@daniellee After restart the grafana was working fine and no errors i have found after the restart.
