Trying to get OpsRamp data to grafana. Not able to locate datasource for the same.
My instance is the trial version. -
Would like to add opsramp api details to grafana,so that it can fetch the data from opsramp. -
What happened?
Grafana Plugins - extend and customize your Grafana | Grafana Labs -
Grafana Datasource | OpsRamp Documentation
Thank you for your reply.
No, I haven’t installed any plugins, as the Grafana instance that I am using is SAAS one. ( Grafana Cloud Portal, 14-day trial of Grafana Cloud Pro to explore unlimited metrics, logs, users, and premium features.)
