Cannot See Oracle Enterprise Manager (OEM) Plugin in Add Data Source List
    9.1.1 on Linux 7, 64 bit
    Integrate Grafana with Oracle OEM 13.5.0.8,
    Downloaded and installed Grafana Server using:
    wget …grafana-enterprise-9.1.1-1.x86_64.rpm
    sudo yum install grafana-enterprise-9.1.1-1.x86_64.rpm
Started the server
sudo systemctl enable grafana-server.service
sudo systemctl start grafana-server
sudo systemctl status grafana-server
Downloaded the OEM Plugin from Grafana Download page | Oracle
Version 3.0.0
Installed using:
grafana-cli --pluginUrl /home/oracle/GRAFANA/V1020218-01.zip plugins install oracle-emcc-app
Modified defaults.ini per enable-oracle-enterprise-manager-app-grafana.html
allow_loading_unsigned_plugins = oracle-emcc-app,oracle-emcc-datasource
*Enabled the service on OEM per the same link:
Restarted Grafana server:
sudo systemctl restart grafana-server
Checked installation of plugin:
grafana-cli plugins ls
installed plugins:
oracle-emcc-app @ 3.0.0
  • What happened?
    Logged into Grafana console:
    Click Add Data Source
    Search for Oracle OEM…
    Should see OEM as a data source.
    Cannot see it, after multiple restarts, still not seen.
    As above.
    No Errors
    How to Install Grafana on Linux Servers
    Oracle mos note 2632952.1.
Welcome
Anything in the log files you could share?
Since I am a newbie, where are the logs?
Found the log.
Found a permission issue on the plugins directory. Set the owner/group to grafana.
Can see the plugins getting registered in the log now.
Had to go to configuration | plugins and enable the unsigned plugin - should be documented!
Now see it in the Data Source screen.
Closing this thread.
