Grafana.net Cloud -
Trying to connect AWS S3 using influxDB to see data in Grafana -
Created Bucket in AWS S3 and a bucket in InfluxDB Cloud then created a Datasourse in Grafana using InfluxDB -
What happened?
Nothing happened, cannot seem to get my MF4 files data to display in Grafana -
I was hoping for data to display on a dashboard -
I do not know where to copy it from. -
Error logs just says No Data -
I have been down many rabbit holes and too many links to paste here, I just need someone that can help me get this working.
